LB7: Airdogll pushes to much fuel
Andyz
Aug 7, 2014
I recently installed an airdog ll 100 gpm and it pushes too much fuel that the check engine light turns on do you guys think that a bad fuel pressure regulator can cause this to happen and if not what can I do to fix this issue
13,736
805
What code is it throwing? You may need to adjust the pressure.
andy-stevenson
Jul 7, 2013
838
Is it on all the time? I know with mine it goes on when I turn the key to accessory but goes off once I start cranking. I've used my Edge to read the codes before cranking it and nothing comes up..
Andyz
Aug 7, 2014
Not sure what code the shop told me it was pushing too muck fuel and they lowerd it to the lowest psi settings
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I have yet seen a airdog set at 8psi like airdog claims. My last one was at 24psi. Everyone I have installed has been over 15
