LLY: Air leak in the intercooler?
dirtymax36
2nd place is last
Apr 11, 2013
367
This past weekend I finally got some new tunes after my 3 inch y bridge and 3 inch passenger side pipe done. All tables changed in the tuning process were desired boost levels and vane positioning. Turbo wise I am running a billet 68 cheetah. I blew the drivers side pipe at 50 psi of boost, therefore I check out all intercooler boots and put it back on using hairspray also. All boots are in great condition. I am not getting a hissing air leak which sounds like it is coming from the front drivers side of the motor. I have searched it up and down looking for an up pipe leak and I even went as far as taking the Y bridge out to check out the O rings in it. Has anyone had a factory LLY intercooler blow apart or start leaking on them? I am picking up some PVC caps tonight to pressure test the Intercooler. The next thing Im guessing to check is the Up pipe gaskets? :confused::confused:
Any help would be appreciated as I need the truck this weekend to pull a tractor home. I already ordered PPE boots and a 3 inch drivers pipe also. Thanks!
xtremebikr04
Jan 17, 2011
573
Vermont
The oem intercoolers are not very strong. I'd pressure test to make sure it is the intercooler.
Side note...
Make a way for the PVC end caps to not blow off. Sand a grove in them or something.
dirtymax36
2nd place is last
Apr 11, 2013
367
Would you happen to know what PSI they tend to bust at? I will be pressure testing it here in about 5 hours and posting results. also where is the cheapest place to get an Aftermarket one?
xtremebikr04
Jan 17, 2011
573
Vermont
I always thought they hold up to around 50 psi give or take. I'd imagine any of the vendors on this site can hook you up quick.
dirtymax36
2nd place is last
Apr 11, 2013
367
Ive been checking out the Mishimotos and BD's. I wouldnt have thought id have blown it after the first couple of times to 50 psi but its whatever i guess.
Ill wait for a vendor on here to chime in. Im certain they're not far away...:thumb:
