LB7: Air dog Fp 150 lift pump
Jakekk1
Aug 23, 2018
I’ve been having issues with the lift pump on my truck I just put new injectors and fpr on the truck. It’s got a 60 hp tune in it and it keeps throwing the 0089 code for higher fuel psi. I have cut two coils off the return spring and it seemed to work for a little while. And now whenever it decelerates it doesn’t drop pressure it seems to build pressure up to about 10000 psi then it drops slowly but I think that is what’s throwing the code. I have also unplugged the lift pump and it runs perfectly. Should I just keep cutting at the spring. Oh and when ever I call airdog they say it’s normal. Plz help.
tsd_billy
457
oklahoma city
Is this a 4g pump or the older style pump.
2,105
^^ 2x
More then 10 psi seems to create hith pressure at idle which could cause looping in some
My LB7 required some tune tweaks to the pressure regulator to help drop the idle PSI down after running higher when I had it more them 10 PSI
Jakekk1
Aug 23, 2018
^^ 2x
Like de fueling? Or adding fuel? I’m newer to the diesel world.
