Aftermrket over flow bottle ?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Any one have links to aftermarket overflow bottles that will work with our size coolant lines ? am need to ditch the factory one because of the hood stack , wanted one that would go along the fender between the turbo and the fender , I know i have seen a few pics on the webby but cant remember were ? any one got any idea's ?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
attachment.php
Stock wont work? Dale got mine ( alluminum ) for cheaper than we could of had it made but this one fits so well that I never changed it.
I found that the fitting on the "T" on the lower hose is a small hole for the size of the hose on my 01....not sure why GM did that the hose.
TrentNell
Jul 7, 2008
7,543
slc tuah
attachment.php
I like it Simon :thumb: , I may have to copy your setup :angel: I didnt even think of putting it were the battery used to be . That is why you make the big Bucks $$ :rofl:
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
It fits very well there Trent, I have a small coatainer that i fabbed up ....It fits between the rad and front head light mounts, Incase it decides to puke coolant it wont go on the tires
I would use silicone coolant hose for the 2 new coolant lines and use a clamp that is desighned for silicone hose.....Dont cheap on them as it will destroy the hose from it digging in, The stock clamps dont work well becaquse you are actually increase the hose OD from useing NON metric
Just my 2 cents:)
9,906
152
Check out Summit racing Trent. Cheap Al tanks on there. I can't remember what brand the one I bought is but I had it made with some minor custom alterations for real cheap!like $100 for a 6qt or something like that.
