Was just thinking... I know everyone goes with grade C GM oem gaskets usually.... are there any companies out there that make headgaskets that are better than the stockers? Stronger material or something?
I havnt hear much good about the Cometics
I know DPR does cutom ones but it requires block and head work $$$$$$
dpr uses gm gaskets
DPR Package price includes Gas-lock Sealing Rings, modified head gaskets, Decking and squaring of the block deck surface, resurfacing of the cylinder heads.
Got a GM part # for them?
they use a grade A gm gasket which is modded to fit the garlock ring which needs to have a retaining groove in the block for the ring.
