So I bought 08 duramax LMM with 6 spd allison. Drove it for a month no problem got finally all the parts and fluids to do the fluid swap. After the change transmission was slipping. I checked the fluid before change and was much higher then standard level but I assumed it was because of dented pan on transmission. So I did add extra quart and I was able to drive it now. But once in a while when I accelerate hard it will slip again. Should I add more ATF or is it something else? Truck has 106K miles on it.
