Ok....
So I am looking to replace my 1792. Working fine right now, but I'm getting all worked up by the sh!tload of posts I see of these 1792/PPE (Essex) pumps failing especially in cold weather. And it's about to get cold here. I don't run a stock filter head under the hood so if it quits, I can't plumb around it and be on my way
I am also too cheap to do it right and buy a Fass/Airdog. I have to buy 2 or 3 pumps, build different setups, try a bunch of shit and spend even more in the end to be satisfied :rofl:
I also run the BD filter setup so I don't need filtration.
I emailed Aeromotive about the 11203 11203 info 140gph, internally regulated at 14psi. This setup would probably need a regulator to keep it around 12psi, so I also asked them about this regulator: 13205 Which allows up to 12psi
This was the response I received:
Todd,
There’s nothing particularly problematic with standard grade, petroleum based diesel fuel, the 11203 pump and 103205 regulator should be fine.
Brett Clow
Aeromotive, Inc.
7805 Barton St.
Lenexa, KS 66214
913-647-7300 Ext. 109
This pump and regulator can be had brand new around $250-260 total.
Ok... so I have a few friends running Holley black pumps and such with their diesels.. and that new 12-150 pump caught my eye. 12-150 billet pump
It comes with a regulator, but it's only adjustable to 9psi max
Price for pump/regulator comes in around $210ish, so it's approx $50 cheaper over the Aeromotive setup. To my surprise, this was the response I got from Holley:
Hello
We do not offer any pumps at this time that are rated for diesel. Please try back at a later date.
So I don't know what to think... I have first hand experience with close friends running Holley products on Diesel. But they obviously don't want to claim it works. So this sounds like more of a risk.
I guess if I'm going to spend the money to replace a pump that's working just fine right now I should go with one that they "claim" should work....
Does anyone here have any experience with either of these pumps on a Diesel application? Have anything else to throw in here?
Todd,
Brett Clow
Aeromotive, Inc.
7805 Barton St.
Lenexa, KS 66214
Hello
