LBZ: Aerodynamic and rub questions
metron
Sep 13, 2012
195
Buffalo, NY
I'm gonna instal the Cognito UCA leveling kit.
I know larger/agressive tires create rolling resistance and decrease MPG. I'm gonna run the factory wheel & tire combo for a while so no issues there but will the change in the aerodynamics due to the truck being leveled instead of raked create a MPG drop?
Also when I do get funds for new tire/wheels, will a 305/55-20 setup give me rubbing issues? I don't wanna be doing and trimming.
04D_MAX
force fed
Sep 10, 2012
384
SOUTH GA
my dad runs 305/55/20's on his all stock and it doesn't rub much if any, maybe on a good bump with the wheel turned all the way, but keep in mind thats with a large positive offset on gear rims. with a leveling kit you should be good
AubleAK
Aug 5, 2011
781
30
Glennallen, AK
Just FYI, if you don't already know, leveling kits really tweak your cv axle angles. I had one on my 01 and with the new torsion keys it rode like shit and sucked in 4wd.
metron
Sep 13, 2012
195
Buffalo, NY
Ya my cuz installed a leveling kit with new keys & i wasnt a big fan. Im not doin the torsion key leveling kit, Im goin with the full upper control arm kit from cognitio.
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
I run 305/50-20's with the keys dropped all the way down and it only rubs the inner fender at full lock a little so I don't think you'll have any problem with rubbing after you level it.
coldLBZ
Apr 22, 2007
2,344
Alberta, Canada
Correct me if I'm wrong, but even with the Cognito UCA's you will still have to tweak the T-bars to get your lift. FWIW I have driven a levelled truck with Cognito UCA's and it rode quite good in my opinion.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I run 305/55/20s with no lift. Torsion bolts probably have 1/2-3/4 left but its rides better where its at now. Rubs at full lock inside the back of the wheel well but I think the bars up a bit higher and I don't think you'd have an issue.
metron
Sep 13, 2012
195
Buffalo, NY
Ya but theyre not cranked all the way up like they would be without the arms
5,806
The arms do not determine you lift. only the torsion bars do. adding the cognito UCA is mainly to allow for a better ride with a cranked truck (it also helps with aligning when cranked). they do nothing to gain height
metron
Sep 13, 2012
195
Buffalo, NY
Ah gotcha, ultimatly im gonna do a 4-6" Lift kit just starting out with the UCA's for now.
