Advice please
rivergoer
Feb 8, 2014
SO CAL
So my truck is a ca emissions truck. I have the blocker plate and finger stick so I'm not throwing any codes for egr. But since I added the edge, cai , Lbz mouth piece, and full free flowing exhaust with down pipe I get the mass or volume air flow circuit low input code and turbo position sensor code. And a turbo/super charger boost control solenoid circuit range/ performance code.. Truck runs great no issues whatsoever .. Just the annoying light. Is there any way to fix this or just keep clearing the codes? I checked for leaks and there are none. Air filter is clean maf is clean.... I cleaned the maf and did the k&n recharge kit all at once. I used maf cleaner on the maf.. Would the Jegs performance maf work?
rivergoer
Feb 8, 2014
SO CAL
Mike diesel said to put the stock intake back on but I do not have that anymore. How do others get around this?
rivergoer
Feb 8, 2014
SO CAL
I have... And I will once I even up with the wife.. I just spent a ton on the truck and myself so if I ask for Eli live right now I'll be living in the truck haha. Need to spend on her a little bit.
paint94979
Beer Nazi
Sep 18, 2006
11,715
Fair enough but there are several guys around you that would tune your truck without the need for buying a V2 or autocal... just 125$ for the license and their time to tune it. just a thought
