Would I use cut pistons or aftermarket mahle etc. And would I have to bore out cilynders? How much do dual cp3s cost? And how much do u think I would have in a build like u said Pat?
Cut and. Coated LB7/LLY pistons are fine. Typically you will bore out the cylinders come time to build. .20 over.
Dual cp3's using stock cp3's are ~$2k iirc (may be off. It's been awhile since I bought a kit)
A build like I said will break down like this:
Used shortblock ~$500 on Craigslist.
Rods of your choice: ~$2200
Then you gotta pay for machine work for the block, balance the crank and key it. Then key the cam.
And top it all off with ARP studs. If you shop around I think it can be done for ~$5k. Keep in mind that's just the short block. If you run big boost. You will need valve springs to stop the valves from floating.
