Well here's the deal. Got block all back in, first few starts it was fine, now I can hear a chatter out of the driver side head, so I believe I had one back off. I plan to remove driver side valve cover only, my twins are all over the pass side so it require some work to get down to the valve cover. I have a puller for the ati damper, but was trying to keep from removing it as it fits pretty snug and won't be a cake walk to remove in truck. I can go off compressed springs but I dnt feel I can get it right, always went off marks. I was planning to bring cyl 4 to tdc, set the valves I can, rotate a revolution and set the others, assuming someone knew what degree mark the ati damper equates out to.... If not I'll pull it and throw oem on just to make sure it's right. Believe problem is in cyl 8 valves only, maybe 6, but definitely backside of the head according to sound
