Adjust your headlights from inside the cab???
twister773
livin the dream
Apr 14, 2007
134
central coast
How many, if any, of you would be interested in this? It will use the same type of switch as the dimmer switch in our trucks but adjust the headlights up and down. Same type of deal as in newer, higher end cars. Would be great for when towing heavy loads as well, etc etc.
mb1
149
Edmonton, Alberta
I was thinking about this a little bit lately when I adjusted my lights a few times to compensate for a load on. For those without bags this would be the cats ass.
Heavyfuel
33
Windsor, CO
i read a thread about this a couple of years ago and found all of the gm parts to make this work. apparently the european models of our trucks as well as the tahoe's (more specifically the 99-02's) came as a factory option with a thumbroll switch as the adjuster. it was even on the dash in a factory location. ill try and find it for you.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Please do Heavy.
Twister.... if its a 100% GM solution Id be interested in doing something with you on it, otherwise theres no way its gonna happen LOL.
There are some HID companies who have a moving bulb that you would replace your headlight bulb with, and different height adjustments.
Heavyfuel
33
Windsor, CO
here you go guys:
(2)HORIZONTAL ADJUSTER:16524772 $48.65 EA
(2)VERTICAL ADJUSTER (CHEVROLET):16533093 $43.08 EA
(2) VERTICAL ADJUSTER (GMC):16533095 $44.16 EA
(1)HEADLAMP ADJUSTER BRACKET:16524537 $82.42
(1)HEADLAMP ADJUSTER BRACKET:16524538 $72.56
(2)HEADLAMP LEVELING ADJUSTMENT SWITCH CONNECTOR:15306300 $35.94 EA
(2) HEADLAMP CENTER BALL PIVOT STUD (CHEVROLET):16532978 $6.79
(2) HEADLAMP CENTER BALL PIVOT STUD (GMC): 16532970 $6.47
(1)MANUAL HEADLAMP MOTOR CONTROL CONNECTOR :15306141 $29.94
(1)MANUAL HEADLAMP MOTOR CONTROL CONNECTOR :12167122 $82.30
(1)HEADLAMP LEVELING SWITCH CONNECTOR :12101822 $56.26
(2)HEADLAMP LEVELING SWITCH MOTOR :16525027 $217.47
(1)HEADLAMP LEVELING SWITCH :15036455 $73.36
if i forgot anything im sorry guys this is just what i found in the catalog as far as this modification goes. let me know if i can help anyone
5,950
here you go guys:
:eek: wow, not for 1100 bucks!!!!! really cool feature though. id buy one but not for that much
Chevmeister
Big Dooley
Dec 3, 2010
281
Garnet Valley, Pa
To bad that headlight leveling switch doesnt have 5 positions. I know someone is thinking what im thinking. Change a few resistors inside and you have a stealth DSP....4???
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
My Up Armored suburban 2500 overseas had this very sweet feature
