LLY: Adding to the family, maybe???
DangerDog
76
Mesa AZ
So after a while of looking, my dad has finally found a Duramax that he likes and is considering getting it this coming Thursday. It's a solid truck, really clean and well taken care of. it's the 04 LLY with the PCV reroute, EGR blocked and the Ice Pick fix. He also has an ATS Stage III with Co-Pilot, Raptor lift pump with Cat filter and DSP5 tuning from Duramaxtuner.com. It still has the factory tie-rods/idler/pitman but is stock height with slightly larger tires, so I'm not too worried there. The only concern we have is that with the engine running and the oil fill cap off, there is visible steam/smoke as well as a grinding noise. The noise can barely be heard with the cap on. The owner said this started just within the past couple months. He noticed it during an oil change, but said it happened sometime after he replaced the water pump with an ACDelco one.
Also of note, the owner said that the truck ran 13.6 on a PPE on level 9, but only a 14.2 on his race tune, which he said should be about 470+ hp. Could this all be symptoms of a cracked piston/cylinder? It's a stock turbo, so no huge boost numbers. I figured the steam was just normal and that the noise was the water pump since I read there was an issue with ACDelco pumps. Could the .6 time difference just be a combination of driver error, less aggressive tuning and enviromental changes? The runs were about a year apart. Sorry for the long winded post, just want to make sure my dad's investment is going to last him a long time like I keep telling him it will. :thumb:
paint94979
Beer Nazi
Sep 18, 2006
11,715
With the oil cap off and my truck running I see absolutely no smoke... sounds not good to me. I personally would never but a truck that is that modified .02
DangerDog
76
Mesa AZ
That's how I normally think too, but the price is right and it looked really well taken care of. It's just this one thing that has me and my dad thinking twice about it. Any ideas to what could be the cause?
paint94979
Beer Nazi
Sep 18, 2006
11,715
blow by... = internal damage. There is a reason why the price is low. If you have or know someone with EFI Live i'd ask the seller if you could scan the truck to see if there are any codes... check balance rates as well. That will be able to give you crucial information
DangerDog
76
Mesa AZ
That's what I was afraid of. The owner has EFILive, which I was going to try and swing into the purchase. He seemed like a nice guy so maybe he'll let me "try" it out on his truck, I'll also see if he'll take it to a dealer to get a compression test.
DangerDog
76
Mesa AZ
The current owner is sending me a screen shot of the injector rates and is looking into getting a compression test as well checking the computer for codes. Should be able to get the results tonight or tomorrow.
