talk to your tuner as it is hard for anyone to know where your tune is. I see your tuner is Mike (MMLMM) he should be more able to help you with this.
Lol i knew someone would say that....
Well it is true I dont know what PW you are running and timing and every other table in the tune. Also it is not like you can post the tune up for everyone to look at (unless Mike says so but I cant that nor could I blame him) so for just tuning changes there is a lot. I could say bump up the PW a bit and see but does that relay help.
If you were looking at hard parts I could see this more like adding W/M or Nitrous or bigger turbo or injectors.
I know what your saying...so if i bump PW up a bit are there timing considerations to take into account also?
Even if mike said i could post the tune (which i doubt he would ) i probably couldnt figure out how to :rofl:
I would not call myself a tuner and I am the one that was pushing my stock turbo a bit too hard. But if you are just bumping up a small amount you could be fine but I don't know where you are at.
Also anything done to the truck other then a tune? are you still running DPF and a DOC?
