Adding Columns/Rows to Tables
SmokeShow
6,818
Lawrenceburg, KY
Can we do this???
I was looking at a pulsewidth table for an LBZ and at the end the columns went straight from 3400RPM to 4800RPM. I want to add the missing columns in between the 3400 and 4800. Can I do that? As it currently shows, I assume the computer interpolates between the two to come up with a value when the RPM is between that range??? I don't like that. I'd rather define a number for it. ;) I did so in a way but would rather just add the columns in there and fill the actual cells. :angel:
C-ya
SmokeShow
6,818
Lawrenceburg, KY
ok, I lied a little. It's the timing tables that I was looking at. I haven't looked at any others to see if the are like that also.
Many of the tables are hardcoded into our software. Ross will take a look at what he can do on the table that you are having a problem with, but you need to tell me which one it is.
In the future alot of this will be easier to setup and change in our V8 software.
Cheers
Cindy
