Adding a fuel pump and sump.
Gee8100
Jul 21, 2017
Elberta,Al
I am going to install a fuel pump along with a sump.
My question is has anyone used the factory draw straw for the return line for the air separator rather than cutting the filler tube and installing the tube in it.
When you have the sump installation the original draw tube is plugged off, just wondering if it could be used for the pumps bypass line.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,239
383
At Da Beach
I wouldn't do that. The pressure from the fuel in the tank could restrict the flow too much and cause problems. Plus, I wouldn't want the air/hot fuel dumped into the tank near the sump..
clrussell
pro-procrastinator
Sep 23, 2013
5,952
421
My Lb7 is exactly like that. I've had no issues what so ever with it, and it's been like this since before I owned it
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
Exactly how I do them. Clean and simple.
deezelpwr
Floating in the Gulf
May 18, 2014
15
BAMA
Let me know if you need a hand, I live in summerdale
6,031
you realize that all returns on the dmax have a tube that run down into the factory sump and are under fuel 90% of the time, right? the purpose is so you do not draw air when running a low tank and helps keep the sump topped off. No matter where you place the return, its going to heat that tank up without a good cooler and you will be drawing in hot fuel. Not to mention the sloshing the tank sees, where it does dump will still get mixed is pretty damn fast
02greysixer
1,829
North Central FL
That's the only way I'll do them as well. Makes for a super clean install.
Sent from my SM-G930P using Tapatalk
NC-smokinlmm
May 29, 2011
5,239
383
At Da Beach
It's been along time since I was in a fuel tank. Why wouldn't you just tap into the fuel return pre cooler. That's how I did all mine...
6,031
you can, just preference.
i dont care for sumps. they dont hold the fuel in the bowl well when you are playing off road on steep grades and have a low tank. the stock sump does much better and with the PPE pick up snapped in there, you get no "1/4 tank" issues, return keeps fuel in the sump, and it has trap doors to help keep fuel in and from sloshing out.
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
Nobody cares about your off-roading shenanigans James
