Add me to the headgasket list
maine04max
Dec 11, 2008
1,009
well looks like another one bites the dust . we pulled the glow plugs # 6 was wet . pulled the tcb batt fuse and turned it over . it blew out moisture and looked to be dexcool . then we removed valvecovers and pulled #6 injector and the cup stayed , so now looks like a headgasket issue . Now Im not sure if I wanna change the gasket in the truck or put it back together as is and just rebuild the Lb7 I have torn down in the garage :baby:
63chevyll
Projects of Many,None dun
Nov 28, 2009
99
Colorado Springs
could be a cup issue? thats the problem im having,
the gaskets look to me like they would blow between clyinders,
drain coolant and try and remove sleeve? you may find something weird?
MaxPowerLB7
Amateur
Nov 8, 2007
623
Spanish Fork, UT
Could be either a head gasket or a cup. When i blew a head gasket all the cylinders on one bank were wet. But if the cup stayed i would guess head gasket as well.
IdahoRob
Jun 5, 2007
1,151
Craig, I'd pull the cup, if you're that far, and look at it. Reseal and install it then test. May save you some time.
maine04max
Dec 11, 2008
1,009
update : we put the injector back in and everything back together . I didnt have the cup tool to remove it and check that so we just reinstalled everything installed new seals (?) on return lines , new copper washer under injector and injector O-ring ( it was torn) . So far truck is running pretty good . The upper radiator hose hasnt been firm yet , but its still early to tell if its still loosing coolant . I have decided to go ahead and build the motor I have in the garage
Pondsy
Jan 4, 2008
641
53
Plymouth, MA
Hope that works and good luck with the build!
nice...good answer :D :thumb:
I like that answer too! haha
