2005 LLY - I've had an occasional problem that's left me on the side of the road twice where the accelerator pedal stops responding. I have my V2 hooked up, and when this happens the throttle position reads 0% regardless of pedal position.
I scanned the ECM and have the following codes:
P2133 - Accelerator Pedal Position (APP) Sensor 3 Circuit High Voltage
P2139 - Throttle/Pedal Pos Sensor/Switch D / F Voltage Correlation
P2140 - Throttle/Pedal Pos Sensor/Switch E / F Voltage Correlation
Has anyone experienced this before? I can try to troubleshoot by checking voltages and such but being an intermittent problem I am not sure that I will find anything unless I happen to get lucky and catch it while it's happening.
