As the title says my AC does no work anymore. This started on my way home from Florida. Middle of Georgia in June my AC starts to get weaker and weaker then finally goes out. Checked charge when I got home and system was still full. Recovered, vacuumed, leak checked system and recharged just to be sure it had proper amount of freon. System static it reads about 28psi on both high and low sides, same when at idle and high idle of 1000 rpm. The clutch is engaged and is getting 14v. Is it possible for the clutch to be slipping? There are no strange noises under the hood or strange noises coming from the compressor. Open to all suggestions. Thanks!
