I recently ordered an ac delete pully and installed it on my truck. On first fire up i thought the new delete wheel bearing was squeaking. After a few days I looked closer to see that the new pully isn't inline with the hydroboost/powersteering pump pully. The ac delete wheel sits back farther toward the cab an easy 3/32" there is an obvious gap. I used the correct spacers that go around the bolts in the delete bracket holes. I even loosened the bolts and tapped it forward to make sure I had all slop forward. Then I found a thread on some forum about a service bulletin, it said something like 04 and 05 having improperly machined ac and powersteering pump bracket? Just weird it didn't squeak before and now it does. You hit the belt with wd40 and it shuts up. I checked spacing on the pulley by laying a level across them. I would say maybe Ps pump pully might not be pressed on all the way but it seems to be on there flush to the shaft. Any info or tips on the situation?
