So I think I've been in LB7 tuning land too long :rofl: I've tuned a few LBZ/LMM's but most were just deletes/turbo brakes. My noob question is: can you fully disable the P0087 limp mode on an LBZ?? I'm so used to tuning LB7's that I was under the impression you could disable it on all operating systems, but I seem to be having a drastic hard time on my buddies LBZ. Now I understand I'll get the "fix it correctly" responses and I can assure you we've done the tests. It's either injectors or a CP3 and it barely drops rail only under the most optimum conditions. The truck is just shy of 400k miles and it runs flawlessly so he is hesitant on dropping the coin. I've tried shutting off the code and changing the "pressure delta" table but that table always puts it in a ghost limp unless I have it set at 22.5mpa. I'm kinda at a lost. Any suggestions?
One other issue. I programmed a turbo brake into his truck as well and the damn thing will surge the turbo when slowing down around 2000rpms. It's the same tune setup I've ran in other trucks, yet his is the only truck that I've tuned that does it, so it caught me off guard. Even opening up the vanes drastically it still intermittently gets a slight surge.
The only thing different is his is a cab/chassis model. Any help will be greatly appreciated! Hopefully the heat has just fried me and I'm missing something obvious! When I get back home I can attach the tune if need be.
