Question: Absolute minumim computers needed to run truck?
Cougar281
1,830
268
St Louis, MO
Ok, so for my random thinking of the day.... What would be the absolute minimum computers needed to run my 04 (converted to LBZ) and have it 'functional'? I'm thinking ECM, TCM & BCM. Add instrument cluster if I want to be able to know speed, temps, fuel, etc. How about my friends '99 6.0 gasser (I'm thinking PCM, maybe BCM)?
Dave
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Dave
ECM and TCM is all that is needed to run it, the BCM is needed if you want tow/haul to work. The cluster isn't required unless you want the factory guages and to know when you are in tow/haul mode. As for a gasser, they only need the PCM to run and function, the BCM if you want to run the stock cluster.
DMAX403
Sep 22, 2010
110
Mackay, Qld, Australia
x2, i'm only using ecm/tcm in my patrol.
