abs light, right speed sensor code, trailer brakes
motobean95
May 27, 2015
Hi everyone I have an 09 2500 and am getting a abs light and service trailer brakes message. pullled the codes and it said front left and right speed sensors. I replaced both and the abs light and message are still on. I pulled the code again and now it is saying the right front is bad. I just replaced it. I looked in the fuse box under the hood and I believe the number 4 and 44 fuses were blown. I replaced those. I also cleaned the ground wires under the driverside door. They have not blown again. So now I am thinking maybe something shorted out. a friend of a friend works at a dealer and looked it over and he thinks it may be the EBCM. Would that blow fuses and also be a cause for the trailer brake message? If there is a shorted wire somewhere I hate to replace the ebcm and have it fry. Any suggestions on what people have seen with these or how I can test for a short?
Thanks in advance
Bryan
