So I've been fighting abs issues ever since I had a caliper blow a seal 6+ months ago.
I installed the new brake caliper and bled them the old school way, without thinking about the ABS module. They bled just fine, but my ABS light has been on since then.
Pulled the codes and I had a code for a bad front wheel speed sensor, replaced it, and now the abs light is off when I first start the truck, but comes on and the "alarm" dings when I get to about 40-50ish mph. Also, sometimes, if I depress the brake pedal while rolling at 40-50ish mph the pedal will vibrate for 1-2 seconds like the abs is activated then go back to normal. This is becoming a real headache, and absolutely bugs the piss out of me. Any help?
Thanks
Thanks
