My ABS light and the brake warning light flash randomly back and forth. When my lights are on and I touch the brake the tail and running lights dim. Turn indicators turn on, but dash lights turn off.
No codes stored. At least none that my programmer or cheap scanner will pull. (Will scan with snap on scanner Monday.
So far I've checked....
Both batteries and connections
Ground under cab on frame
Ground under ds battery on frame
all bulbs in tail light assemblies
all marker light bulbs
I'll check ignition swich voltage next. If it's ok, is there anything else it could be other than the ABS control computer? How can I test the ABS computer?
Any help is appreciated.
