LB7: abs brake light disable?
MuscleTruck03
Wants a turbo!! or two...
Mar 10, 2010
369
north ogden, ut
hey guys Ive changed my tire size in efi but every once a while I get the "anti-lock system error" or whatever on the display... any reason for this or a way to get rid of it? maybe a dtc I could change or something? thanks
Madspeed
Fat Bastard
Mar 22, 2007
315
Elk Ridge Utah
The problem is that you went to far on tire size in your ECM and now you need to have your abs module reflashed so they arent out of sync. I could run up to a 34.5 tall tire in my ECM before it popped and abs code. Unless you actually have an abs problem :D if so tell me what the code is
MuscleTruck03
Mar 10, 2010
369
north ogden, ut
Well its a guy my dad works with, but he has 37s on it and I put the size in at 36. Ill have to find out what the code says or if it even has an actual code
05' Ditry Duramax
May 3, 2008
1,294
42
Port Orchard Washington
You have to reflash the ABS module to a Kodiak tire size. I can't remember the size exactly. You'll have to have a dealership do it with a Tech 2 (good luck). I pulled the fuse so the light and dinger bell goes off as soon as I start the truck. I use my remote start so all that noise is done by the time I get in.
