Okay ... just a question or two about Ideal Gas Law in regards to turbocharging.
Is the Ideal Gas Law the same with gas AND diesel?
I am using PV=nRT equation to figure ideal air mass for my engine. Don't wanna get too complicated, I am just more or less playing because I desire to learn more about turbocharging, especially map reading and A/R.
P=Absolute Pressure
V=Volume
n relates to mass
R is a constant
T=Air Temp in Rankine
Is this the right equation?
Will anyone with EFI Live who logs frequently tell me what IATs you are getting when you drag race or sled pull? I am thinking 130-140 deg.F.
So ... what I have come up with so far to find out n(lbs.min) at 35 psi of boost and 3600rpm is 95.33612 lb/min. (THAT seems awfully high.) I do not want peak hp at 3600 rpm of course, but that is just a hypothetical number that I am using for MAX. rpm
Am I close?
The equation I used to find lb/min is
n(lb/min)=(14.7+psig) x Vcfm x 29 / 10.73 x Rankine
P=Absolute Pressure
V=Volume
n relates to mass
R is a constant
Am I close?
