Abnormal Tire Wear
WC911EOC
My work number is 911
Nov 9, 2009
17
Northeast Pa
I was checking out my front tires on the truck the other day and noticed my passenger front is wearing funny. It seems as though the center of the tire is getting worn down faster than the outsides. The tire on the drivers side is fine. I changed the wheel bearing on the drivers side and IIRC this started occuring after I did that. Is it time for another bearing for the passenger side? possibly an alignment too?
Thanks in advance guys!!
WC911EOC
Nov 9, 2009
17
Northeast Pa
Here's a pic of what it looks like, take a look at the middle tread...
WC911EOC
Nov 9, 2009
17
Northeast Pa
Whats a safe PSI to set them at guys? should it be like 10PSI below the max? or is it better to keep them at the max? I never quite had a definitive answer on that...
rick67
Jan 20, 2010
50
Indiana
Look at the tire info label on the driver's door jamb. recommended front should be around 60 front, 80 rear iirc.
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
I run mine around 50 in the front. If your running D rated, I wouldn't run them too hard. I ate my BFG's in 17k.
