Instead of making several threads for a few issues, I'll just make one.
I also searched and couldnt fine many answers (my searches may have been too specific though)
1. Steering wheel knock? I know that a lot of people have issues with their steering wheel shaft knocking and grinding while turning. Is there any updated OEM replacement shaft or oil that can be used to solve this? Even maybe use an exhaust clamp to clamp down the shaft?
2. What type of brake pads do you guys use? I installed a set from Advanced Auto Parts about two years ago and ever since, my brakes squeal so loud every time i stop. Its annoying and embarrassing.
3. My drivers side taillight goes out almost daily, and occasionally my reverse light. My tail light assembly has a broken pin at the top keeping it in, so that may be why. Does anyone have any experience with aftermarket tail lights? Or is OEM the only way to go. Another thing, could it be wiring that causes this issue?
4. My passenger side air condition blows hot occasionally while my drivers side blows normal. I used to have this issue with my drivers side, but I pulled the actuator and cleaned the gears on it and no issues on the drivers side since then. Any clue?
If anyone has any suggestions, that would be great. I would go over to Duramaxforum, but there is so much clutter on that site
