97 Lumina - ABS/Brake lights
Cougar281
1,830
268
St Louis, MO
How do I figure out why the ABS & Brake lights are on? I figured I'd need a Tech2 to do it, and I just purchased one. Problem is, when I go into the "Chassis" section, it times out saying no comminication after I select the Body type (I'm pretty sure a 97 Lumina is a "W" body). Body & Powertrain work fine. Am I just looking in the wrong place?
Edit: Figured it out... Started poking around with the help of Mitchell's diagnostics, and found that the _______ Monkies that where working on it before me unpluggd one of the plugs on the EBCM :rolleyes:. Idiots.
