742 code tq converter clutch
J17HENRY
May 23, 2009
alabama
Rolled into throttle in 4th nice and slow, shifted out fine. Then I stopped at a light and it shifting funny. read the code 742 tq converter clutch stuck on, cleared the code drove truck again same thing. Truck wants to pull all the time foward or rev. How can this be fixed? thanks.
15,681
Converter went south.
15,681
Easy way is to just replace it. I personaly have not seen one do it. If the solenoid was at fault, it should kill the motor.
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
It wouldn't be that restrictor falling out of the transgo valve would it? That's exactly what happened to mine.
Edit: That's assuming you have the transgo converter valve installed.
J17HENRY
May 23, 2009
alabama
I would guess it has the lock up valve not sure. It is a suncoast kit and converter. How can u tell if that is the problem?
J17HENRY
May 23, 2009
alabama
drove the truck and it was really lungey kinda like a manual tranny. just before I pulled in the drive it set 700 and 872 code. the 742 code has not come back.
