-6AN Turbo Supply Mod
kidturbo
Piston Tester
Jul 21, 2010
2,540
1,378
Somewhere On The Ohio
www.marinemods.us
Since I'm on a AN kick this week, decided to post this on up for review. Needed 2 turbo supply lines off block. Rather than pull off the oiling main ports with 4AN lines, I just modified the PPE remote filter adapters. Welded a -6AN bung to it, now not robbing a main bearing supply.
Wasn't using that port for temp sensor anyways. It did require drilling the adapter block out to same size as the AN hole before we welded the bung on.
Sent from my SAMSUNG-SM-G870A using Tapatalk
kidturbo
Piston Tester
Jul 21, 2010
2,540
1,378
www.marinemods.us
Thanks Bac. They say necessity is the mother of invention. And this build has definitely been a motha...
After a bunch of reading, I found no real consensus on which port or ports in the block are best. One thing is certain, I wasn't using the factory LML port...
We had to build a special plug to block off the valley port. It's just below the bolt pictured. After doing a little measuring on main oil supply passages, I think this new location should have least impact on crank bearings.
5,840
If anything, you are pulling pressure from all the mains equally since it will hit the adapter first before going to the mains
kidturbo
Piston Tester
Jul 21, 2010
2,540
1,378
www.marinemods.us
45deg hose end fits my setup perfectly. But will probably not play well with the stock L adapter used on PPE oil cooler bypass hose. For that setup it will likely require a 90 on thw 6AN.
