66mm turbos -- give me some ideas
1,802
Need a list of decent 66mm (2.6") chargers, BESIDES Danville and Fleece Cheetahs.
Before you ask, no its not for my truck. If I do anything, I'll twin the stocker first.
1,802
Also, curious about install kits, too.
Which one is the best bang for the buck? PPE?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Give me a call Tom , either for the whole shabang or for install kit , I have all the parts on the shelf now and several different turbo choices , including full 5" intakes !
02bigstrokin
Sep 9, 2008
882
i have a pedestal from e.d. its a cast one and fit perfect. i wouldnt buy a ppe install kit. they suck. we have put 2 on around here and they never fit half way right. save your money and piece together a kit before you waste it on a kit that will piss you off whne installing.
White Duramax
158
ohio
I have a HX55 holset that is 65x98mm compressor wheel. 1.0 t4 housing, ran it on a BD pedestal with adapter. Made good power and daily drove great.
CrazyDaze
800+HP Build!!
Apr 6, 2009
57
Auburn Hills, MI
Thanks for getting started on this for me Tom! :thumb:
Trent...I contacted Bullseye with what I was looking for and they sent me back a reply suggesting a CompR 66 T4 .91 turbo with a race cover. Are you familiar with this turbo? I'm looking for 40-50 pounds of boost from it. Do you have an install kit for it?
I'm building an LB7 for pulling. Want somewhere between 700-750 rwhp. I have a lot planned for the engine so it can handle that. My main concern right now is air, exhaust, fueling, and keeping it at a 2.6 class truck.
TrentNell
Jul 7, 2008
7,543
slc tuah
Give me a shout i have a install kit for it , but not positive its the right turbo for your HP level desired , but would need some info on what the spec'd out on the comp side , just because its a 66mm doesn't mean its an "of the shelf" unit , could be custom machined .
maine04max
Dec 11, 2008
1,009
I have the bullseye 366 with race cover and htt 16ss housing . last time i dyno'd it was 658 1190 .
CrazyDaze
800+HP Build!!
Apr 6, 2009
57
Auburn Hills, MI
Trent...is your contact number the one on your site? I'm wicked serious about being at that HP level!
I'm taking that was on stock injectors, and engine with good tuning. I'm planning a little more and hoping this turbo paired with some good injectors and enough pressure to feed them is gonna get me there.
maine04max
Dec 11, 2008
1,009
running 60 over extrude hone injectors . the local dyno is known to be very conservative. the dyno owner told me most will dyno 50 -75 more on load style verses his inertia dynojet 248 . tuning was not set to max effort
