64mm ihi limit
NRA223
May 20, 2015
288
I'm wondering what the most power anybody has made on a 64mm ihi is fuel only. The most I've seen is 644 on a dts 64.
NRA223
May 20, 2015
288
Not sure on what mine has. Basically I'm trying to decide on what the next step for my truck is between manifolds and up pipes or cp3 upgrade. I'm not sure if my stealth 64 would benefit from more fuel or not.
NRA223
May 20, 2015
288
I already have the lml manifold so thats a plus. Do you think with the stock turbine wheel i will need that much fuel or would a sportsman pump do?
yellowchevy
1,926
82
Louisburg, KS for now
A sportsman pump will give you more fuel on the top end but duel fuelers will make it more responsive and power down low. This is just my findings from talking with others that experience with both.
I'm assuming now your stock LB7 CP3 is running out of fuel up top and your exhaust is clear?
Yellowchevy
NRA223
May 20, 2015
288
No pressure codes or anything like that but the exhaust does clear up. My truck only has 60000 miles on it and fpr was replaced last fall.
NRA223
May 20, 2015
288
I haven't logged it but under wot the edge shows a 23.2k desired and 22.8k actual.
diesel53
Sep 16, 2010
907
AZ
Nevermind I see what injectors you have. What does the 64mm inducer and stock turbine make with stock injectors and cp3?
yellowchevy
1,926
82
I really though stock injectors could support more power than that. Maybe not?
As others have said, depends on tuning/setup. Which dyno you're on, operator, and sampling/setup range also plays a big parts as well.
I've seen some dyno numbers change 50-100hp from dyno to dyno when nothing was changed on the pickup.
Yellowchevy
JDub
607
Hooper, Utah
We've built well over 100 64mm IHI turbos in the last 3 years and have yet to have one come back with a broken shaft. Have had some returned to be repaired for other issues, but never a broken shaft.
