600hp, 4th gear?
JakeBrakeIH
Dec 24, 2010
406
Yaphank, NY
At what point do most of you guys start using 4th gear while pulling? I know most of the tracks in the midwest are super tight power tracks, meanwhile up here in the Northeast that is hardly the case, with just a few exceptions. With that being said, is 600-650hp enough John Wayne to spin 4 sts with stock 3.73s in 4th gear? Also when coming down down to the last 20' or so, do you guys just unlock the converter or shoot down to 3rd? Just looking for some different opinions and thoughts.
E.carter
637
42
Princeton, Iowa
Thats a very tough call, I have said oh shucks a few times when reaching for fourth. I usually have good luck hitting fourth in the 8000lb class even on tight tracks but when your in the 8500lb class fourth I have found to be a very bad idea. I hit lock right out of the hole and unlock towards the end when the pan drops our I feel my speed dropping. I love the way my truck takes off when unlocked in fourth gear. I also have no idea where I am power wise but I just know it runs very well.
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
I experamented with this a bunch. I live in ohio so tracks are tight. 4 sts's and you will not be able to hang with that power in 4th gear. stay in 3rd. I was running the same and went to my drag tires which is toyo at's and tryed 4th gear and could hang it on loose tracks 285/75/16. I would still have to unlock the tc at the end and that was at 8000 pounds with 1000 on the nose. All in all i still went with 456 gears and still had to unlock the torque converter but that was with 35 inch dc at's only on tight tracks though. If you run alittle smaller tire and a good not so biteing at tire like the toyo or something similair you can run 4th but make sure you got a unlock switch for the end of the track.
Schwinn68
little gearhead
Jan 9, 2008
632
Minooka IL
I agree with ecc. the unlock switch is key for trying fourth. I had those sts on my truck for two hooks. first one was in third gear on a tight track and it pulled the truck down so bad at the end, it almost snuffed the truck. I'm running about the same horse level as you are.
JakeBrakeIH
Dec 24, 2010
406
Yaphank, NY
I have an unlock box so that would be good. I guess I will just have to bump up my pressures and try it on a looser track? I also have a set of 305/65/17 ATZ's I could try on the super hard tracks? Its almost like this HP level you either need to regear to get some RPMs back in 4th or stay in 3rd with 35" tires or something?...
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
This next year I am looking at trying 4th gear. I have some where in the range of 600 - 700hp. I am running 305/65/17 KM2's. They seem to hook hard but I feel I am running to high of RPM's and I am thinking of trying to get some more boost out of it also.
bubba2400
Jul 19, 2009
199
Union Grove, WI
Six of the STS's should help too. Remember if the motor makes power at 3k rpm and you can run 4th at 2700-3000rpm it will most likely be faster than third. Just have to look at some gear charts and try it when it doesn't matter to see if it will hang.
RichLMM
699
North Kingstown RI
on stock internals we're not gonna want to lug the motor that much i ran 4th with 35's at the last hook and it dragged the motor down to 3K while the truck hooked and took off it was cringing listening to it
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Maybe my 33's will run a little higher RPM range in 4th. If the motor goes then its time to upgrade. :thumb:
JakeBrakeIH
Dec 24, 2010
406
Yaphank, NY
Haha I wish it was that easy to build lol.
So I could do a few different way I guess...
A.) 4 33" sts 4th gear
B.) 4 35" duratracs 3rd gear
C.) 6 33" sts 3rd gear
It really sucks, like mentioned earlier the tracks around here are marginal at best. I know of maybe 3 tracks in the area that are power tracks.
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Im in the same track condition position. Maybe 2 or 3 around here are ok. The rest are all over the board. I will try 4th gear next year and see what happens.
SmokeShow
6,818
Lawrenceburg, KY
For the 600-700ish level I like the stock gears with 35s winding out 3rd gear! Start making 700+ & it's going to really wrap the rpm up in 3rd & you'll be able to hang 4th.
But then it's time to re-gear so you can get into 4th sooner (<100') and be wrapping up the RPMs hard by the last 1/3 of the track before unlocking or spinning out if it's as loose as you say.
