6 speed Allison won't move under ~100*F fluid
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
A friend dropped his truck off a couple days ago, 06 LBZ, if you try reverse or forward it will start to move and limp out of gear and throw a shift range inhibited and codes p0700, p0751, p0761, p0762, p0877... If you let it run long enough to get over 100-110*F on the trans temp it will run and shift every gear just fine..
My first thought is fluid level low?!? Any suggestions or similar situations?? I'm gonna look at it after work today, just wanted ideas for things to check out.
Thanks in advance for any help or suggestions.
03_DMAX
Aug 15, 2010
124
Pull the main harness plug and see if its leaking oil. Had one do something similar before.
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
I forgot about this, when I received the truck, and 10*F outside temps the trans fluid level was not even on the dipstick at cold idle...
I dropped the pan and put both filters on trans, got fluid level corrected, and no codes anymore.
melms23
253
WI
Glad this got bumped up. I'll have to check it out, I didn't think it was such a simple fix.
