Having possible trans motion troubles on my pulling truck. Have a 4th gear start tune that I have ran for years. Hi stall suncoast converter. After going to the engine dyno and placing the motor back in and it sitting for 6 months with our current state. The truck won’t shift out of first. Speedometer is reading when moving. No codes, only code that has come up is a po2764 replaced solenoid, still same problem wiring harness was new 2 years ago. Had zero issues when I pulled it into the shop to pull motor only thing that was swapped on trans was the converter, but have a hard time thinking that’s is what is not allowing it to shift, any and all help appreciated
