Question: 6-spd Allison Wiring
SmokeShow
6,818
Lawrenceburg, KY
I'm selling the 06 2wd from my donor since I'm going with a ZF6 in the 83 conversion.
Not sure which way is a better way to ask but here goes...
In a nutshell, I don't want to sell off parts with the transmission (particularly electrical parts) that I may end up needing in my conversion. So, what can stay and what can go?
Particular concerns are a) the wiring harness, (b) steering column wiring and (c) the bcm and wiring associated with it.
(a) I'm thinking there shouldn't be much I need from it except the VSS signal wire, right? There's surely not much electrical going to or coming from a manual trans to the ECM??
(b) Biggest concern is the shifter. What, can go with the shifter should the buyer want or need the shifter? I'm assuming I'll need/want to keep the ignition. Other than that, can everything else go if need be?
(c) I'm thinking that I won't need the BCM or anything to do with it since I'm going manual trans and transfer case and no tow/haul, tap shift, etc. that may run through it. Does anything to do with the throttle control go through the BCM that will require me to have it in the 83?
If I can get some guidance on any of that or anything else someone knows or can think of, I'd REALLY appreciate it!!
TIA :beer
