Dood
Do it:thumb:
Pay very close attention to your rim specs and tire width, ie back spacing/et and drive type ie where the hub mounts, usually designated by RWD mid mount or FWD I think, but I'm guessing you're trying to stretch a 12.5 a bit? I have no idea what the rim specs should be for that wide of a rim, but I'm running a 285/75/18 which is a 35" tall tire x 11.65 wide on a 10" wide wheel with a 4.5" BS and +12et and I'm fine on a 4" lift
On a 6" you should be just fine with a 14" wide wheel running a 35x12.5, so long as the tire is stretched some it should work, if you were trying to go for the "mudder" look with a blocky or balloon tire profile I'd say you're nukin futz though....
I want...
No.
I demand pics when you finally decide to pull the trigger, please pull the trigger as I think this will look killer :angel:
