I am putting a 6" lift on my truck here shortly.......I was wondering if i would be able to clear a set of 20x14 -76 offset and 35" tires? If anyone has this setup please let me see a picture. Its going on my 08, thanks!
How wide of tires? I have 20x12" -44 with 35-12.50's on my 15 with a 6' inch lift and I don't have the t bars cranked much at all i can't fit my finger between the rubber jounce pad and the lower control arm and it clears but not a lot I bet you will have to crank to get it to clear in the back of the fender. mine clears by 3/4" or so. I could level mine up as it sits an inch lower in the front but I like the way it rides and no rub but quite a bit of bumper trim. But I do have a lot to turn up so I guess you will find out.
