I recently changed jobs and I don't work from home anymore so I commute. It's been a record warm summer here in the PNW and I'm concerned about my transmission. I have an 04 LB7 with about 176k on it. The tranny runs about 100 degrees above ambient temp (this is based on the OEM dash gauge, not an aftermarket one) which I read is normal , but when it's in the 90's outside it gets to about 200F. That's when the flared shifts start. It's pretty bad traffic (90 min to go 21 miles) so you can imagine the wear I'm putting on this aged transmission. I replaced the fluid with Transynd hoping that would help, and it did lower the temps by about 10-20F but the shifts are still flared when it gets hot. These shifts are really bad. Like scary bad when it's at its worst. Then, the next morning when the tranny is cold the downshifts are very rough. Shaking the whole truck when slowing for a red light, etc.
Is this normal for a 5spd Allison with this many miles?
Is there anything I can do to fix or at least improve this?
Could it be some kind of build-up in the valve body that a fancy additive can fix?
Should I try a new NSBU switch? It also lags between R and D and the PRNDL display is blank (but I think the backlight is just burned out).
Anyone want to trade me for a truck with lower miles? ;o)
Thanks in advance for any help.
