Where is the 5 volt reference wire located that feeds the fuel pressure regulator, baro sensor, throttle pedal app2, rail pressure sensor, etc. I seem to have pinched or broke this wire and need to find it on a 05 lly thanks
Check all of the connectors on the engine and make sure they are connected to the right sensors. Did you do some work then the code came about or just happened to pop up a code?
