5 inch backspace
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
That is what we run. Depending on the tire you might have to cut a little.
Sam
Mar 31, 2010
Midland, TX
Ill be running the MT et radial 2's in 305/40/18
You'll rub a little, the reason being is the -38mm offset (If your wheels are 12" wide). I'm guessing thats your offset given 5" backspace, how wide IS your wheel? That tire isnt that big, only about 28" diam but.. it's 12" wide, and with that offset.. that tires gonna be way out there.. and you're gonna rub.
Why do you want this tire size? Have you bought your wheels yet? i could probably find something better for you if you havent :)
NJ_LLY
Back in action
Nov 4, 2008
560
Browns Mills, NJ
Im getting those tires because they are the biggest drag radial. If you can find a tire as big or bigger ill buy it. No bigger that 31
