I've been talking to Rossler about building one for the Chevelle, he says a 400 will be stronger, but I need the overdrive so we are going to "try" it and see what happens. He says I can shift into od under full power, which is something most builders can't do. He mods them with some special black majic shit for this to be possible. My car is 4400lbs, prob 1000hp and shifting at 4000-4500. Not sure on the torque but its a single turbo lb7 with nitrous, your guess is as good as mine. He wasn't very warm and fuzzy about it, but said that no one else out there can build it better, so IF I was willing to try it, then he was willing to build it (with no guarantees, other then it would be best there is)
I should be ordering mine before then end of the month. Then you need to decide on the converter, I haven't started calling companies yet but I have a few in mind and so does Carl.
