4088r, 4094r, or s366?
2005LLY
Sep 18, 2011
379
Which of these would have the fastest spool up and support 600hp reliably?
Truck will get 45% nozzles, and studs the same time it gets a turbo. I just want something to spool extremely fast, tow a 9500 lb boat, and be a good daily driver, I am open to other options? I like the danville 68mm as far as vvt goes. My truck now is just laggy and I dont like it.
Dylan
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
Laggy stock turbo????
The 4094r gets my vote. Water and oil cooled plus the coolest non annoying turbo sound that only garretts have.... T4 too so you can upgrade to a real turbo down the road
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
40/88R will spool the quickest.
40/94R will make a little more power then the 4088
both turbos will support over 600RWHP.
TeaBagger2006
May 11, 2008
3,123
15
Bis ND
Must be tuning then.... But that's not important if you're planning on upgrading it. What if there be something wrong with your truck...ie boost leak? But anyways don't buy none of that Borg garbage! Garrett fo' life
2005LLY
Sep 18, 2011
379
100 shot i think .046 jet or .46 don't remember what it says on it, and no boost leaks, I was told by my tuner he thinks it has to do with not having my egr blocked off, and that it losing back pressure is why its laggy.
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
Blocking your egr should help reduce spool time. It helped mine.
S Phinney
4,008
Quncy, Fl
BW turbos are easily rebuilt were Garretts are not. Price difference is substantial. Rollers are more durable but at a cost.
