355 65 18 toyo at
diesel53
Sep 16, 2010
907
AZ
anyone ran these? Is it going to pull alot harder over a 34inch tire? Im either going with the toyo or federal couragia in a 35 12.50 20..
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
That's basically a 37" tire. What exactly do you mean by pull harder? I run toyo a/t's in my sig and love them. Very quiet and smooth
diesel53
Sep 16, 2010
907
AZ
Thanks guys that helps. I'm concerned with the 37s changing my gearing so much I'm losing power to ground. Ya I definitely don't want a soft compound tire
diesel53
Sep 16, 2010
907
AZ
Another issue is I have an rcd 6 inch lift. Will they fit without jacking the torsion?
TeaBagger2006
May 11, 2008
3,123
15
Bis ND
a 355 is 14" wide. i have an 8" lift and my bars are cranked, but my wheels stick out quite a bit. unless you do a lot of trimming and find a wheel with the proper backspacing i dont see them treating you nice
