You're right, that one appears to be done pretty well. I couldn't tell for sure but it looks like the vss is still on the tailshaft of the 2wd allison. If that's the case, I'm curious if or how his alli knows how to shift correctly when in 4wd and if or how his speedometer reads correctly when in 4wd.
I wasn't meaning to say that going with a SFA and divorced xcase was a jerry rigged setup. It certainly can be done and be done correctly. In fact, it can be done multiple ways. Of which, some will function as a 4wd, meaning all 4 tires will pull, but without the appropriate wiring, it won't function like it's a factory application - i.e. the shifting and speedo issues I asked about above. It's not that big of a problem to get one to go into 4wd physically. If it's not important for the speedo to read correctly or shift appropriately while in 4wd, then yep, there's not much to slapping a sfa under there or even getting the IFS system to work. Conversely, if factory-like function is desired to where all systems work just like a factory 4wd would when in 4wd, then it is a good bit more work to get it right as far as electronics goes.
And I realize it seems as though I was coming down on you in particular for your idea. I really didn't mean to. I simply quoted you to discuss the 2wd to 4wd via SFA in general, not to really address you personally on the subject. Sorry about that. What I'm trying to point out is that to do it right and make everything work correctly in 4wd (not just have all 4 tires turning aka jerry rigged) it takes a good bit of work and still requires all the same electrical stuff when talking about using the alli. The divorced xcase just adds another element of fabrication to it.
I don't have all the answers or else I would have already done this because this is what I was trying to do - convert a 2wd IFS to 4wd IFS. I'm 99% sure I'm forgoing that idea and going about it differently.
