I have a bad 4x4 tranny and can get a 2wd for cheap will it work if I swap the adapter plate?
P pat5001 New member Jun 1, 2010 46 0 0 Dec 4, 2010 #1 I have a bad 4x4 tranny and can get a 2wd for cheap will it work if I swap the adapter plate?
Vrabel TOYAHOLIC May 22, 2008 3,434 0 0 57 Hewitt, NJ Dec 5, 2010 #2 I believe rear output shaft is different too.
Dalyfarms New member Jan 12, 2010 76 0 0 Centrailia Mo Dec 5, 2010 #3 I had the same deal on a 79 Chevy, had a extra 4 speed setting in the shop, I had to swap the rear output shaft between the transmisions before it would work. Of course I have not been that deep in a Allison so I can not say for sure. good luck
Mike L. Got Sheep? Staff member Vendor/Sponsor Aug 12, 2006 15,681 232 63 Fullerton CA Dec 5, 2010 #4 Unbolt the complete extension housing as a unit and switch them.
Mike L. Got Sheep? Staff member Vendor/Sponsor Aug 12, 2006 15,681 232 63 Fullerton CA Dec 5, 2010 #6 Watch out for the little parking pall spring. Call me and I'll tell you how to save it.
duramaxdiesel Dmax Nut Oct 23, 2008 1,378 0 36 47 Montreal, Canada Dec 5, 2010 #7 Now that right there is service!
