Do any of Ya'll know where the Big Nitrous runners are placing there 2nd Nozzle, and how big of pill there using?
Thanks
Joey
Thanks
Joey
Crazy kids these days!!!
The problem is i'm a 33 year old kid Chris!!
The second stage could be put in the place of the IAH (in air heater) in the intake manifold with a plug that's taped for a 1/16 NPT. The SD manifold (Pat or Kat can get these for you as well) can accept up to 5 nozzles if needed (4 on the LLY/LBZ unless customer request more ports). It's a quick bolt in item that replaces the silicone boot after the I/C on LB7s (up top on the passenger side) but on the LLY/LBZ replaces the one right after the turbo (up top on the drivers side).
... Just trying to get a 11.5 out of her then i'll be done.
Joey
That's what we all say.
"I just want to run a 14, 13, 12, 11, 10 ..."
Joey. Yes it's me. You can see them at my site if you havn't seen others with them installed. It just eases the install of extra things like this and provides access for boost and such (pane, W/M injection and so on). If you really need to go for 11s, do it only once, put it down a back away (if it lives through it). I've found some other issues were going to be dealing with from the motors in trucks running this much power in stock form (built motors will be dealing with it too). It's not kind to them inside. The jet to start with is dependant on the amount of fuel you have. I use to run a .128 and some times a .132, but I had the lines, solenoid and moded nozzle to handle it.
Joey
