My tires on my DMax are almost gone and it's time to buy new ones. I'm struggling, like everyone else on here after reading all the posts, to decide between 285/75/16s and 265/75/16s .
I pull a 12,000 lb 5th wheel RV from May thru October on really long trips somethimes, and I drive about 60 miles total to work and back every day. I want the 265's for the extra benefit's for my truck, but I like the look of the 285's Here are my pro's and con's for both:
265's - better gas mileage, better for towing (gear ratio, ally shifts, etc.), not quite as ballooned/stuffed on the PYO's as the 285's. But don't look quite as tough.
285's - look better and ride a little better, but gas mileage suffering. Worried about rolling/sway when towing camper.
I would still go with the BFG A/T's, but there doesn't seem to be that much size or weight difference in the two to justify switching:
265's - 31.7", 54 lbs
285's - 33.0", 57 lbs (only 12 lbs difference for a whole set?)
If I did switch would i need to go to something a little less agressive to get the full benefits (BFG Rugged Trail T/A E's @ 52lbs)?
Input (pics?) from all of you who have had 285's and went down to 265's or vice versa would be MUCH appreciated! I want to be talked out of switching to 265's, or into stayin with the 285's. Want to keep the look, but also want whats best for towing/fuel mileage.
THANKS!
THANKS!
